Decided to start a new thread on the 404 with a better title. This will be my dumping place for photos and progress reports as the project matures and should be easier to identify when browsing topics.
The original thread is here:
http://www.classicboatclub.com/forum...hlight=project
Latest news is that I was able to get rid of the siezed Johnson last night. I do have the controls, however, so if anyone has a need, drop me a line. They seem to be in good working order mechanically. Not sure if the starter switch functions, but it does turn and return as expected.
One thing I noticed right away after removing the engine is how dry everything looks back there (surprising on a boat that has termites -big fat termites- living in the cabin). The bolt holes have no visible moisture and the wood looks pretty good. I plan on removing the trim strip on there and having a look at the top some time this week. If things look good, I may not do any work there at all, outside of hole filling. If it is questionable, I may take a few core samples to inspect the plywood.
If the wood is no good, what is the reccomended best practice for replacing that material? The fiberglass on both sides looks really good (minus a few holes here and there from brackets being mounted in days past). I'd rather not destroy any of the original glass on there as I doubt I could lay it up again as nicely, or as stoutly as it is now. Is it simply a matter of painfully digging out the wood with a long chisle (doesn't sound very fun, and how do you get to the deep down parts)? Or is the only way to remove the deck and cut out the glass on the inside of the transom to replace the wood? I'll post some pictures of it once I get a chance.
Also, still looking for some knoweldge on identifying the year. Builders plate has 404-1114 as the hull number. Any ideas?
Thanks guys!
Thanks guys!
