I'm a new member to the club, and also a bit of a computer dunce, so am trying to familiarize myself with how to operate this site. Hope I'm in the right place!
I am currently restoring a late 50's 22' Bryant cruiser. This is my first classic boat restoration. After pulling all the floor boards and doing some restorative structural work on the fore to aft battens, I am now waiting warmer weather to go after a good sanding, fairing, and repainting of the exterior hull.
While I wait for warmer weather, I am going through the accessories wiring, electric start connections for the 1960 Johnson 75 hp V4S, and also the steering connections.
The boat came with the original Vollrath Vi-matic steering system (single push/pull cable). However, I do not have any of the mounting hardware for the cable (transom mount?) nor whatever linkage is necessary between the end of the steering cable and the outboard. Can anyone let me know where I might find the necessary parts here? I did find one old ad for the Vi-matic steering system which lead me to believe that the cable might have originally been hooked up running fore to aft (parallel with the keel) and connected to the side of the motor. However, this does not seem possible. Most of the older pictures I've seen show steering cables operating side to side (perpendicular to the keel) with various forms of linkage required.
The motor checks out good, though I did have most of the seals and several bearings replaced. The electric start wiring harness is also in good shape, but I do need to find a new keyed ignition switch for the dashboard. Any suggestions here for finding this part?
Thank you. Looking forward to new acquaintences through this site.
Charlie McCrum
Charlie McCrum
