Hi All, I need some recomendation on a high qualitiy gas valve I've read mixed reviews on Moeller,Sea Choice looks like a couple more dollars but any different any help much appreciated.
Three Way Fuel Valve
I have used the Moeller valves both in Marine and the truck industry with no issues.
Hey Paul,
I`ve seen these mounted with plates that have numbers and on/off stamped into Alum so you know which way is what.
Seem to recall someone having one switched off when it was thought to be on.........StirPot.
Moeller took over Tempo when they shut down for good.Sea-choice is kinda a cheaper made part in most cases but Brass items like valves are hard to cheap out on.Might even be the same supplier.
A see -thru glass filter downstream from the valve will let you "see" what`s flowing and whether oil has thoroughly mixed in the main tank.
TMunk.year 10` Mahogeny "DragonFly"racer
