Not trying to get into a pissing match or anything, but any boat will exhibit the same behavior whether it is full of foam or air. The only difference is that water cannot displace the foam if the deck or hull is breeched. Having it on the side may help water not stay on the sides if the boat goes sideways, but if you are that far over you are going to lose it anyway. The only way to keep a boat hull down is if the center of gravity is below the waterline. In sailboats they accomplish this by heavy keels. On a runabout, not so much!
I guess the real question is, how does the other 21 handle in the rough?
