With all this nice weather it's time to tear into my 1960 Seafair Sedan to see what time and water has done to the poor girl.
As you can see it's not good news but that was expected. Actually it might be good news after all because there's a bit of a hook in the hull and I may be able to straighten it out when I bed the new stringers in. This is what I found below the new transom I removed.
Yes it's always good to check the work of the previous owner. The good news is the new transom was easy to remove with just a utility knife and a large screwdriver. The floor was also removed with a utility knife and a little muscle. My plan is to put the boat on blocks so it's nice and square then proceed with the transom before doing the stringers. The transom looks straight forward using two layers of 3/4" exterior plywood using glass mat and vinylester resin to laminate everything together. Should I use 1708 over the whole thing once it's in and tabbed?
The floor is another matter because I plan on sandwiching the rear two feet or so between two pieces of plywood and screwing everything together to make it nice and flat while I install the stringers in hopes of eliminating or reducing the hook in that part of the hull which was a result of a few years on a trailer that was too short. Does this sound like a good plan?
