While I realize that generally "too much" power is seldom enough, I'm wondering what a reasonable amount would be for my 19' Bell Boy.
Currently it has a single 40 on it...have another identical engine...so would 40 or even 80 be in the ballpark? It's not my intention to set speed records and I certainly don't want to make our arab bestest buddies any richer, just want enough oats to get on plane without taking forever and to be able to maintain speed in less than ideal conditions.
Too low a power rating often results in worse economy than a more powerful engine(s).
Just found a 75 horse Evinrude that has the same style shroud as mine (Lark II) and the thought popped into my empty head that this equates to only 5 horse less than a pair of engines but offers the simplicity of a single engine. What does thou thinketh?
 If you run one motor you will need a kicker for backup because I believe your boat is too big to row.  One of my reasons for going with twins is that if one breaks the other will get me home quicker than a kicker.  Of course my Bearcats will allow me to troll all day without a kicker also.   While the size and performance are important I believe also that you need to be sure how and where you are going to use the boat and then decide what motor or motors will work.  Getting on a plane is not that hard but then will you have to continue to run wide open to maintain the plane or can you throttle back to a more economical rpm and get good fuel economy and range?  More questions than answers.
  If you run one motor you will need a kicker for backup because I believe your boat is too big to row.  One of my reasons for going with twins is that if one breaks the other will get me home quicker than a kicker.  Of course my Bearcats will allow me to troll all day without a kicker also.   While the size and performance are important I believe also that you need to be sure how and where you are going to use the boat and then decide what motor or motors will work.  Getting on a plane is not that hard but then will you have to continue to run wide open to maintain the plane or can you throttle back to a more economical rpm and get good fuel economy and range?  More questions than answers.    Barry
  Barry
