Have my winter project lined up. There seems to be at least 4 paint jobs (I am pretty sure 1 layer is just house paint!) to go through before I get to the base layer. Instead of sanding all winter, is there a chemical stripper that works well without danaging the fiberglass topsides?
Paint stripper for fiberglass
Don't try to save $$$$
I used Smart Strip and like Steve says Citrus Strip works well also. I did make the mistake when I striped the white paint off the Dorsett - I got about 90% of what I was doing done and ran out of Smart Strip. Thought I only had a small patch to do and bought a cheaper brand and figured " I can watch it and be careful " bad move - blistered the spot I was doing and I had to sand it smooth and then skim some color matched Gel coat over it then buff . Cost me about 3-4 extra hours of labor to fix it . Had to go back and buy the smart strip to finish. Saved nothing ! Take your time and let the product do the work ,it takes time to bubble .Attached FilesRick & Sarah
Peel away
I recommend Peel Away. Brush or roll it on, cover it with waxed paper. Let it sit a few hours...8 - 12 hrs, then pull the paper off and the paint comes with, usually multiple layers at once....
Works great for bottom paint...
Don't leave it on more that 24 hours.....
McSkagitCaptain Tim (McSkagit) Jones 1959 Skagit 31 Saratogan
I got it. and then I got excited for a minute.
I tried the chemical paint remove and had bad results. So I just sanded everything down with a plam sander. Took FOR EVER, but the end result is nice flat surfaces on the deck.John Forsythe
