Cont. from New Members - Skagit Hideaway:
Here I'll be posting updates and pictures on this Skagit 20 project. So far - the hull/cabin has been completely gutted - all wood removed. The hull and deck separated and a new rub rail tab epoxy-sandwiched between what was left of the original upper/lower halves. No plasic rivets - biaxial on the inside.
What's planned:
I just put in a new, 2" wood core (curved) transom (with new stringer ends) which I like a lot, but now I think I'm going to fill in the cut-out and put an extended bouyancy bracket/platform on the back for twin outboards (dreaming of twin E-Tec 90's) and so the dog can get in and out of the water. That will give us more cockpit space too.
Twin, 27 gal, aluminum fuel tanks (saddle) - diesel heater/window defogger - cabin insulation - full electronics - hot plate and sink in the rear of the pilot house (Alaskan Bulkhead) - head up front in the cuddy.........
In light of the group discussion concerning the hard ride the Skagit has, the idea of a keel/central hull area modification to increase the amount of vee a bit comes to mind. I know that in some cases, adding a box keel solves the rough ride/stability problem. I'm thinking of something similar, but more streamline - adding say, 2" depth to the keel and then tapering the hull, 6" on either side, to the hight of the original keel - full length. Any thoughts/experienced out there with that?
