Thanks Helmar! I've gone through almost a gallon of the fiberfill. I didn't use it on the gas tank boxes, just left a small gap with popsicle sticks and tabbed the three pieces to the hull and floor then removed the spacers. That's what I've been using to make the pattern, I'm on my second large box of the popsicle sticks and lots of hot glue.
I think with practice the Windows could be made very well, but I didn't want to spend the time or money practicing. I'm not sure how strong they are with a big wave hitting them, I used 1/8" probably should be a bit thicker.
My ideal plan for an outboard is either an Evinrude 90 or 115. Those two units are where they switch from 3 cyl to a heavier 4 cyl, not sure if the extra 25 hp is worth the weight or possible price difference, the evenrudes are the lightest I've found. I'm open to more input on power, allthough I'm sure it's a lot like the makes of truck as to what's better, opinions.
When I do fiberglass work at work and when I did the boat I wear a disposable hooded tyvex suit and an old fresh air hood with supplied air. It is almost pleasant and I get very little glass on me with the positive air pressure. I have an old diving compressor for home that I use, so it is breathable air.
The gas tank boxes I do plan to make some cushions for extra seating. Thanks for the coast guard regs I've found them online.
Thanks for the feed back!
