That's what I was looking for, thanks! I'm still a ways from getting the floor painted but the info helps with my planning process.
Wood replacement questions
Finally made the decision about seats. We had gone to many boat stores, Cabela’s, bass pro, ect over the last year trying to find seats that are comfortable to us. They either sit up to straight, to big for our smaller frames or just plain cheap and uncomfortable. I wanted to try these Tempress Probax seats but of coarse no one I could find in western Washington had these seats to try, all this water and boats... Made it over to Idaho earlier this fall and found them at a boat store outside of Post Falls, they said they are very popular over there and they sell a lot of them, instantly comfortable, so that is what we got. We have smaller jump seat type for the rear seats. These came in red and white, but I’m glad we went with the darker grey with a little red. It took awhile trying to find the right height pedestals with swivel and a slider for the drivers side, but found em and they seem to be the right height.
Working on wiring now, have the majority of it ran but not much hooked up yet.
I’ve been researching bilge pumps and am leaning toward a smaller maybe 500-800gph for the mainland a large back up maybe 2000, I had a 1500 in my fiberglass jet boat and never had a problem with it pumping enough water, but I was always within site of land in that boat. Any suggestions or opinions on multiples or size of bilge pumps?
I had a 1500 in my Uniflite and never had an issue. I'm going with either the 1500 or 2000, nothing smaller. I keep a manual pump as a backup, just for a battery failure scenario. Knock on wood, I've haven't had to use it yet.
Those seats look comfortable and look like they belong. Curious on the height? It's hard to judge by these pictures... are the pedestals adjustable?
The seats are depending on where measured 30” from the floor and 15” from the top of the boxes. The pedastals I think are about 9” and the drivers has a slider so the seat slides back and forward and adds 1-2”. There not height adjustable, I couldn’t find any that short and adjustable.
The seats I do like, I was originally wanting a bit more period correct look but comfort won out.
Slowly working on misc tasks. Wiring is going well.
Where do most people put the bilge pump exit on the Skagit 20’s? I made the bilge area size almost exactly as it was originally. I’m thinking if I exit out the sides of the boat under the splash well it will be to close to the waterline. I don’t really want to cut up through the splash well if I don’t have to, but I don’t see another option. Any suggestions?
Originally posted by sclapsaddle View PostSlowly working on misc tasks. Wiring is going well.
I suppose you could put them down lower but you would have to trust a scupper valve. Not sure i would be willing to do that.Helmar Joe Johanesen
3 potential options:
1) Out the back through the transom (not ideal but it's where modern boats discharge).
2) Discharge out the side near the back of the stripe, below the rub rail and above the trim.
3) Run a hose long enough and keep it loose under the splashwell and manually switch it on while hanging the hose over the edge.
I'm not yet sure what I'll do. I may go option two and paint the discharge fitting the same color as the stripe.Last edited by Kelly; 01-01-2019, 07:52 AM.
Originally posted by sclapsaddle View PostI think I'm going to punch holes in the splash well and seal the hose coming through, so I can keep it high. I'd prefer to not go through the wood in the transom, so I will probably go out the side by the trim, up high. Thanks for the input!!Helmar Joe Johanesen
