As a few of you know, i recently discovered what my dad has had sitting in his yard for 20 or so years. And i managed to get it out of the dirt with bottle jacks and on to a dilapidated trailer for transport to my house. Many projects around the house and life have really allowed me to get going on it like i have wanted but i by snowfall it should be in my garage where i can get going on it for the winter. Plan is to have it done by late spring (when all the ice is gone and it has warmed up for some enjoyable cruising. This first post is going to be a baseline for what i plan on and mostly bullet points.
What we know
-its a skagit
-its 20'
-its got shades of seafoam green,white, and blue (pretty sure it was originally blue and white judging on the some sanding and wear spots.
-it has had an inboard, inboard/outboard, and a kicker but never an outboard as a main engine.
-it has the short keel
-it had a rudder port
What we think
Its a 58 (no id tag yet)
the merc turns over so we think it still runs
the outdrive works but may be seized up
What we have in store for it.
Hull
-Getting everything smoothed out
-patching holes fixing cracks
-a fresh lay up of mat-roving-mat on the keel
-fresh paint (may goto the red with white trim)
-fixing the upper glass cowl
-replace the glass/plexiglass
-smooth inside of hull and paint
-beef up transom
-beef up engine stringers
-raise deck to a self bailing level
-build a hard top
-redo cuddy bulkhead
Electronics
-VHF with short whip-NMEA2000 compatable
-Shore power and generator hook up for honda 2000i
-Simrad 7'' touch screen gps/radar/sounder (with implements for guages, ais, autopilot, nmea2000 comp)
-bluetooth stereo for 3'' guage slot with 2- 6.5'' speakers
-inface mercuiser 3.7l to nmea 2000
-all in one nav light led (has the anchor, port, stbd, and aft all in one for mast mount)
-engine blower
-cabin lights (led)
-switch panel
-wiring for 2 batteries(one for start, one for house)
Motor, propulsion, and steering
-Mercuiser I-4 3.7L 170HP
-replace starter
-replace broken shifter bracket (if anyone has one i'll buy it)
-r and r outdrive(transom gasket) new ujoints at the very least)
-convert to altenator
-tune up(points, plugs, wires, coil, cap)
-order up some kind of nmea 2000 steering since i don't have any.(reason being i can make it autopilot, but mainly because drive by wire doesn't rob power or weigh as much.)
The other stuff
-Make the hard top (as close to original, but it will be removable)
-suspension pedestal seats (because cushions aren't enough)
-6'' cushions for V berth/toilet cover/table
-loose lay laminate for table (its slightly softer and has a little texture to it for a non slip effect)
-cuddy cabin curtains
-implements for engine coolant heater.
-semi fixed propane bbq that can be used for any type cooking, and heat in a pinch
-storage cubbys under v berth for anchor line, tools, parts, gear, clothing, bedding.
-8'' cleats on aft corners, spring, and 1 on bow.
-open top chocks on bow
-maybe a windlass
-build a console from scratch for both sides
-bigger than stock fuel tanks (converting to aluminum, and going further forward)
-Motor cowling
-refinish bifold door original to boat
-NEW TRAILER
Safety
-2 10# abc extinguishers
-flare kit
-3 PFD's (will swap between immersion suits and life jackets depending on trip)
-life sling
-epirb
-horn
And its really late and that took alot longer to type up than i though.
now i'll post up some pics for ya.
What we know
-its a skagit
-its 20'
What we think
Hull
-beef up transom
-build a hard top
Electronics
-engine blower
-cabin lights (led)
-switch panel
-replace starter
The other stuff
-maybe a windlass
-Motor cowling
-NEW TRAILER
Safety
-flare kit
-life sling
-epirb
-horn
