58 Skagit express 20' Restore (up north edition)
  • #46
    Looking good Gabe! Bummer about the falling out, hopefully that ends soon.
    I'm a little envious that work is still getting done while you're at work, that's cool that your dad is willing to keep at it!
    • #47
      Been a while since i posted so heres a photo dump.
      the port side had a crap layup where someone had glassed over the gelcoat and we had to plug the fwd vent hole (formally for the oem inboard setup). We ground, we found cracks so we are making it right. Conclusion is that it was hit there at some point.
      on the stbd side we primed and painted the lower trim stripe with interthane 990 crowley red.(10% thinner reduction) Sprayed with a touchup gun just to see how it would lay and if we even could. So it looks pretty good after one coat. We shall proceed on with this paint once the rest of the hull is prepped.
      Gabe Williamson
      Soldotna, Alaska
      Work - 2001 Bollinger Mini OSV 150' 2 Cat 3516c hd
      Side job - 1978 Bruno Stilman 35' Rebuilt in 1993 (38') Ford Lehman SP135
      Play/projects - and works in progress between Dad and I
      1958 Skagit 20' Express - projected Mercruiser MCM170 or 4stroke 115 outboard
      1964 Reinell 18' - 85hp Mercury Almost ready for seatrial
      197? Glassply 24' - Ford V8 I/O
      • #48
        Glad you are still working on finishing her
        • #49
          Here’s another photo dump. havent touched it since early june because work and summer time but,
          -engine is in, bolted down, aligned to outdrive
          -sterndrive is rebuilt
          -wiring harness is ran to just outside of console
          -hoses for bilge, cooling, and hydraulic steering are in
          -my simrad go5xse gps is here
          -ram mounted on stern drive
          -hard top completed to primer
          -mocked up hard top on window frame
          -stbd fwd window is in
          -all cleats and chocks are in
          -gasket and hinges are in on hatch
          things in mock up
          -battery boxes
          -bat switch/maintainer
          -bilge blower
          -trim pump
          -wagner helm pump
          -gauges and switch panel
          -helm seats and pedestals
          in limbo
          -engine cowl
          -fuel tank (being built)
          -port lower and 2 upper windows(lexan and plexiglass are out everywhere do to covid)
          Gabe Williamson
          Soldotna, Alaska
          • #50
            things in mock up
            -battery boxes
            -bilge blower
            -trim pump
            -wagner helm pump
            in limbo
            -engine cowl
            She is looking good for sure. Doing what you are doing, that boat will be around and a Classic for a Very long time.
            I hate seeing these old girls going away as once they are gone, thats it, gone is Gone.
            Thank you for saving her !!!
            Tell me more about the fuel tank that is being built.
            The 58 I have for sale or selling has two smaller tanks up next to the cabin bulkhead and being used as foot steps.
            Helmar
            • #51
              66”x10”x18” down the middle, diamond plate and will be 5200 to deck (top will be flanged to overlay existing side decks)
              Gabe Williamson
              Soldotna, Alaska
              • #52
                Going with springfield gas adjustable 13” -19” with above deck base for both seats. Got one ordered up and it works perfect. As for the tank, our friend welded up a beautiful 50 gallon flush mount that will be just held to deck by 5200 on the corners.
                Ive been talking with kelly about windows, stressing about it, and going back and forth about what im going to do. I think im just going to do lexan(acrilic/plexiglass or whatever) i can get my hands on up here as its so hard to get a hold of up here. I may call an audible and buy a windshield and cut that myself if i feel comfortable on a couple practice pieces. I know i can do plexiglass so i keep defaulting to that.
                also been on the helm console quagmire. Been drawing up different layouts in 3d to get some inspiration there.
                anyways, i hope to have at least one of these 3-4 things finished next days off.
                Gabe Williamson
                Soldotna, Alaska
