Ok, so this will work for pretty much any boat that has the air box in the front. Normally you would leave that air box alone as its a Flotation device for most boats but this one has flotation closed cell foam under the floor board from front to back.
With our Upgrade in our software, we can now ad Captions to the pictures which I will also do.
First things first, make the pattern.
This will show how I made up the pattern, cut it out, made the opening and did a dry fit.
Well, I can see I can add a short caption to the photos but no word wrap. Will look into that later.
Because of the anchor hold door is now on a hinge, This door will be able to attach to the Hatch cover. Open the hatch cover and, if hooked up, the anchor hold door will open the same time.
This will allow a easy access to dropping the anchor line, rode and anchor into the anchor hold. A small clip will be attached to the bottom for a strap that will attach to the anchor rode so once you have the anchor in your hands, you can lower it down into the hold, hook the anchor rode clip to it and lower it down after the anchor. That way, once you get the next stop, you open the hatch over which opens the hold door, using the strap hooked to the bottom of the hatch over, pull the anchor rode, unclip the strap, pull up the anchor and then lower it over the side.
