Hello everybody,
I am about to start the process of replacing the transom, and probably the stringers and floor in my 1964 Dorsett Catalina. This will be the first time that I have done this type of work. I have a few questions before I start doing any cutting, hopefully someone will know the answers.
1st question(s) - I was told that to remove the transom plywood I will need to cut the floor back, because the stringers are attached to the transom. Is this correct? How far back should I cut the floor from the transom, I also need to inspect the stringers during this process. I don't really know what the layout or position of the stringers are, I have looked at several different photos but I'm still kind of cloudy about it. Do you think that a "handheld stud finder" would show the stringers through the floor, like it finds studs behind sheetrock? If anyone has photos of the stringers in a Dorsett Catalina would it be possible for you to post them. Which tool would you recommend to cut the floor with?
2nd Question(s) - I am lucky in that, I have a friend that lets me stay in his cabin during the summer, when his family isn't using it. However, its a small "lake cabin" that they don't use during the winter, because its not heated or insulated and they are afraid of freeze-ups. I have a annual camping permit for the State Park and I will continue the work there this winter. I will stay in the cabin of the boat at one of the campgrounds, its quite comfortable. I have two' 9000 BTU, "Buddy Heaters", one for the front cabin and one for the enclosed canopy area. I very seldom have to run these heaters on "high", maybe on a cold morning for a couple of hours, that's it. I guess my question is, how cold or at what temperatures can I use fiberglass resin? For instance, say its 29 F degrees outside, but inside the boat, in the enclosed canopy area where the transom is, its 65 F degrees. Can I wet-out fiberglass cloth with resin and have the resin cure as its supposed to? I have a couple of 12v oscillating fans to move the air around and maintain a more constant temperature. Hopefully, I will wet-out the fiberglass cloth during the warmer daylight hours, giving the curing process a few hours of warmer ambient temperature. The example I explained is during the nighttime, Do you think that I will be able to do the fiberglass work with a reasonable amount of success? Is there any advice or tips for doing fiberglass work in cold weather?
I intend to leave Wednesday, 10/3/18. I'll be going to Logan, NM. (near Tucumcari), and I'll probably stay about 10 days. I keep the boat stored there and use it on nearby Ute Lake. I'll be staying either at a friend's cabin or at Ute Lake State Park Campgrounds. I enjoy camping at this park during the winter, usually I am the only one in the campground. There are a few day-use visitors from time to time, but they generally don't stay long. Actually, staying in the boat is kinda fun, I have a small kitchen set-up, and the front cabin has color tv and I can pickup 16 OTA channels. "Free" OTA channels from Albuquerque, Roswell, 4 PBS stations from Portales, and some from Amarillo, plus I have a media player that I can use to play movies from a flash drive. So all in all, not to bad. I wish the park had Wifi so I could use the forum to ask questions while I'm there. There is however, Wifi at the Subway in Logan NM, about 15 miles away. I'll use it if need be. The elevation at the park 4200 ft. so it doesn't get to cold, but in the summer it gets very hot, 100 F +. I am including a few pictures so you can see what its like.
I look forward to your answers, and want to thank you for any responses or information.................Pats.
