Helmar,
I was reading your post and I think it's going to turn out looking great. I read you were thinking about your back seat, and keeping the boat light. I am attaching some pics of how I did my back seat. I did them in a modular set-up. I only use what I'm going to need for that particular trip. The small doors on the rear bulkhead have lift-off style hinges. I keep my fuel tanks behind the rear bulkhead, to fill them I just lift the doors off and place them out of the way. The fold down rear seats also have lift-off hinges and fold down legs, when not in use I fold them down for more space. I also use the fold down seats as my kitchen area. I place a Coleman Stove on one of them, and the other seat used as a kitchen counter. I have a full length seat cushion and back if I need a complete back seat. Sometimes I don't load the rear folding seats at all.........it makes for more room.
16ft Bell Boy Restore
I did a little more today on the demo part. Still pulling old wood out.
I was able to open the floatation chamber (what I call air box) and got it all cleaned out. I see I can move it forward if I needed too but I can also see how to seal that up as well as dump it full of foam.
Its looking between the floatation chamber and cabin bulkhead that I can put in two 6 gallon tanks and then the one12 gallon in under the splashwell. Which was Way too low so bringing that up so she does not take in a bunch of water.
In one of the pictures, it shows the hull open, not painted, then you see the sides of the floor, which is the Hull sides below the chine edge of the boat. Its were the hull rolls under the boat.
I planed on putting down some heavy matt or roving but the trim area of what you see that is blue next to a stringer, that lip used to hold the floors plywood next to it. I am going to cut that down and just make a pyramid fiberglass stringer out of it. Then were the floor stops, roving from the plywood up to the chine edge. May have said that already....
All that is left to demo out is the transom. The transom is 20 1/2 tall so she is a long shaft transom so no fussing with that other than, not sure what I want to put in as a transom at this point.. It will carry my Bearcat with no issues as its been done before on one of these.
I ended up putting the laser back in and checking the stringer tops. Looks as I can just run a plank down on top of the stringer and just popsicle sticks hot glued to the plank, down to the deep side or Inside closest to the keel. The start taking measurements every few inches back until I get on the flat side of the hull. That way once I take that templet plank and lay it out on the stringer, I will know at what point to tilt the bed on the band saw.. Once I get it cut and placed inside on the hull, I will take some Fiberfiller and run it down were the stringer sets and set the stringer on that bedding of filler. What oozes out, I can bring it up the sides as I will start the layup of matt, roving, matt, roving and give myself at least 1/8" or a tad more fiberglass stringer covers. If the wooden stringer was to Ever rot out, it would make no difference as I pretty much am build fiberglass stringer over the wood ones.
Here are some more pictures of the take down demo work. I am documenting every step I take.
Oh, I forgot to add that
Originally posted by Super Sportster View PostWhen I winterize the Homelite I put a 50/50 Mix antifreeze into a pump can then pump it into the Pee Tube until it starts running out the leg. Always make sure the drain holes in the gearbox are clear too, I think I did this when we resealed it.
Dick
Dick
Originally posted by Super Sportster View PostI'm following along looking at progress pictures. I see the "flatbed" trailer in the shop, looks dark outside and I'm wondering if it's those lights I got you are lighting it up so nicely in there? We've got some new lighting at work and these are unbelievably bright and compact but spendy: https://platt.com/platt-electric-sup...x?zpid=1075003 Two of these in a 40 ft rusty tank of a barge sure brightens it up! They are small and light to use.
I see the the boat trailer you scored, now that looks identical to mine and I'll tell you right now you'll need to add to more rollers outside of the fwd center. My boat cut the center roller in half in a very short time and I think yours is going to be heavier than mine. You'll also have more weight up front as mine has the 12 gallon tank and battery in the back.
Will this one take a longshaft Bearcat?
Looks like I've put mine away for the winter. I was hoping to get one more trip over Mt Hood, but after getting caught in the snow once and almost putting the truck and boat in the ditch twice I'm pretty sure I'm done. What I FAILED to do last time was treat the fuel, I didn't use the Homelite for three years and it cost me. She runs perfect now and the fuel is loaded up with a can of SEAFOAM. It will be good to good next year. The new top is great, bought a Buddy Heater and it's the perfect size for in there.
Yep you need to get 'er done and see if we can get together for an outing somewhere. I pulled mine out to Promontory in Oct for the first run with the Ranger, oh what a gutless pig. Best small truck I had for towing was the old white '70 Datsun, that was a pulling SOB for sure.
Dick
I was looking at that void you are talking about and yes, i think I want a couple more right about were your talking about.
I have been looking and if I raize that front air box and bunk only 3/4, maybe 1" higher, I would be able to put a 6 gallon boat tank on each side. If I was to put that 12 gallon tank in up by the bulkhead for a foot stand, that would give me 24 gallons to run that Bearcat on, which means I should be good for a three day weekendSip Sip Sip.
So Yes, the Bearcat will go on the back of her as I have seen them on them. Marty had one on his Bell Boy too.
John Nelson has a older Ranger that is a 4 cyl I think and he pulls all his boats around pretty much with it, I know he used to two the Uniflite with it...I know its not a V6 in it. I will have to check with him..
I have the Uniflite out and ready to go but now that the lake down here has been drained, I missed my window so I have the barrel at the back of the boat and will fill that up and let her pull her own water in so will treat the gas, open the pet cocks and drop the water out and just go park her for the winter.. Two years on the tags and they have been setting right here on my damn desk, Never took her out ;-/
Dick
Originally posted by Kelly View PostI always like your pics of suspending boats...you did the same for the Uniflite. They just look cool that way. I'm certain you'll have this boat finished before I'll have mine in the water so that gives me something else to look forward to.
I do each and every project as if it was mine. I want it Safe, I want it to Last.
Once I do get done with this thing, I will know its safe and will outlast me. You know, I have Never totally done one for myself and I think this boat will be it.
Its small, will work wherever I want it too down here. If I wanted to bring it up there, engine change as I will not sacrifice my Bearcat in the salt water so my dream motor would be a 50 Honda 4 stroke. Just don't see that every happening.
Why, I just did a Reality Check.
I am 71 years old and how long can I keep doing this was the main thing. I really miss the fishing I used to do with my kids and want to do that with my Grandkids now.
I need something small and light, something if I have to stick my old bones in and lay down, I can.
I can pull this around even with my little Tracker if need be.
My 20 foot Skagit offshore, I will go though that to the point were she is ready for a Bucket list to the San Juans, then up and down the Columbia River all, with a For Sale sign in the windows. She is just more boat than I need to be trying to haul around (which I only have one 10mpg rig that can do that).
I think after this Bell Boy is done, I am going to start liquidating the shop and equipment.
As much as I wanted the Dorsett Catalina for my last boat, she needed everything. So does this Bell Boy, but like the Catalina, this boat has only one piece missing, she is complete.
Once I get to the point I can't launch and retrieve this boat, that is when I put her up for sale.. Like yours, I will document ever step taken so the next person knows what they are getting. A new Classic boat.
Hell, I might not even Paint this boat. Almost like a Rat Boat, who knows.
I was hoping for one last job to finance this build but that does not look like its going to happen. I am running out of time.
Helmar
Ok, I got her on the cradle trailer and it took some time to get her setup and dead on.
Once she was secured on the cradle trailer, I had to walk on the sides below the chine edges and outer stringers and down the keel. That is Way more flimsy than i thought it would be.
With the stringers Shot in most places, I was still able to shoot the laser and then build some stringer jigs. They are all marked where they go and have one more I think to make up.
This one has a Very Long air box forward that I have not cut into yet. Instead of making the cabin bulkhead by having it attached in all 4 points, it was only attached on the port and starboard side and just nailed across the top on the map deck. No kick plate looked lke it had ever been used. Forward from that were the air box is, about another 2 feet forward is a bulkhead that goes just above the chine edge where its turning up to the bow. I can see were that would add the structure needed to it so no twisting.
The stringers were the tops are open, I can could dig the wood out with a plastic spoon. Pretty rotten.
I was trying to keep the weight down to a minimum but I think I am going use some fiberglass Roving and all teh wood stringers that I am going to put back in would be nothing but a jig to hold the fiberglass roving in place for curing. After they are set, the wood is of no use as she would have fiberglass stringers. The wood will act as a bed for the deck screws is about all that they would be useful for.
I can get a smaller fiberglass structural roving than what I have now that will be plenty heavy and just build the stringers out if it, then from the chine edge down to the stringer, then in between the stringers. Then foam it. This thing will outlast My Grandkids !!
Here are some pictures as I have demo'ed out more of the boat, now to get into the air box as the stringers will go though that up into the bow area.
Oh, was able to get the Bell Boy off the boat retrieval trailer and just put it on the trailer it will finish with just to move it around. The game plan is to back it into the shop, lift the boat with the slings, pull that trailer out and then set her down on what I am going to call my Cradle trailer where I will block up to the chine edges.
Good news is, the keel is Dead On with using the laser. If I just set her down on the keel, she relaxes just were she should be.
I put her on this other trailer to be able to move it around plus wanted to hit it with the laser just to see how she would relax on that trailer.
I did not demo the whole insides of the boat as of yet as I wanted to see what I was working with and, once on the cradle trailer and secured, then I will finish gutting her.
Then back side she goes and I will scrub the living shit out of it with Simple Green, pressure wash it again as I want it Clean.
I might even pull out a patch of that old cloth were its still a little dirty and do a sample resin glass up with it, just to see how well it sticks to it. If I can't get the sample patch apart, then I know I am good to go and this will just double up I am thinking of covering the stringers with fiberglass mat as well.
In looking how Thin the hull is, I am thinking, no, I Know I will use the Fiberlay close cell flotation foam under the new floor.. I want to keep this boat as Light as I possible can but also need to make sure that I do a build up on the sides of the floor. All they did is lay down some extra Cloth between the floor and chine edges.
Too many hidden rocks down here in the Columbia river and other rivers so I am thinking of laying down some heavy roving. I want this boat to just Bounce up and over rock croppings, not stick them though the hull.
I will mark up one of the photos so you know what I am talking about. The Blue area is the bottom Hull, and I put red arrows on that, then on the sides, I put red arrows pointing down at the Chine edge. That blue area is what will be built up with the heavy roving.
I am also going to play with the back seat, splashwell area thinking I want to put in a splashwell bulkhead and raise it up until it starts Not looking right. I am also going to raise up the bucket as they use to put the battery and fuel tank in with the motor. Not going to do that. So up that comes and even at a angle so I will be really limiting how much water she can hold back there if I get a wave over the stearn.
Now that I am thinking about it, I am going to go hunt down the pictures of that little Green Bell Boy as I think Marty raised the floor in that one. Not sure I want it up that high but will check it out.
So, the game plan is to keep this boat as light as possible but still structurally sound..
I just sealed up the Cradle trailer and had changed the wood stove in the shop to take 2 feet long Big Hunks of wood so built a big fire to help the curing. By morning, I will be able to pull it out and back the boat in for the slings.
Oh yeah, almost forgot this. I used the pressure washer and on the Insides, I was able to take over over 75 percent of the paint so, Lots less Sanding !!
showingHullsm.jpgDsc06121sm.jpgDsc06122sm.jpgDsc06123sm.jpgDsc06124sm.jpgDsc06125sm.jpgDsc06128sm.jpgDsc06129sm.jpgDsc06130sm.jpgDsc06132sm.jpgshowingHullsm.jpg
Originally posted by sclapsaddle View PostLooks like only one of the glass is broken, do you have another or do you have to make all new ones?
Cool boat! As typical with these lots of work with rotten wood. Sounds like a good plan, great to be able to move it in and out as needed.
