You might have a few little voids right next to the stringers but with the amount of flotation you will gain, its not much of a loss.
We like to put a couple of ABS 1/2 pipes up through the cabin bulkhead and run then to the rear bilge as so if any water gets in the cabin, it can run back to the bilge and get pumped out.
If you decide to do it like the pictures above, save the hole plugs you cut out, tap down the foam as so you can put them back in, glass them in, then the sweet part is to glass mat the whole floor right up to the hull sides as well as the cabin bulkhead back to the bilge area.
Any rain water that gets in the boat will be forced back to the bilge.
Even if the cabin windows get left open and rain gets in, that would also go to the rear bilge.
Joes 2 cents
Joes 2 cents
