Helm... help!
  • Helm... help!
    Hi all:
    Just trying to get this boat in h2o befor summer ends.
    How do I install the helm(see attachments).
    The wheel is mounted to a long cylinder which houses the gear that attaches to steering rod. Seems like either I'm missing mounting brackets or I can just fabricate it some way.
    Question is does cylinder mount verticalor horiziontal or any way so as not to bind ?
    Photos would be helpful as the wheel works in almost any position
    Thanks
    Delvel
    I would abandon that setup and put a new teleflex steering system in for about $120.00. That way you can do it however you want. It appears somebody long before you took it apart and did it their way. I could be wrong as I have never seen a setup like that before.
    Greg Jr.
      Helm Help
      Looks to me like a basic Quicksilver rack.
      The wheel is held on by a long bolt, if so,and once the wheel is removed,you mount the Black part first which is called the Bezel.You might use a scrap pc of plywwod to mock it up once before hacking the real dash.They usually use a 3`` hole and should have a trio of bolts that keeps things from twisting when you turn the wheel.Some use a u-shaped plate as a backing.
      If bolts or any of it is amiss,then do as Greg said and get the whole she-bang,with bezel kit to suit the dash....either angled or a straight type.
      If trying to save the old deal,shoot some spray lube on threads before wrenching so they come apart.The rack can be de-greased and lubed up with white Lithium to keep if moving easy for awhile.
      The rack systems do offer a good mechanical advantage over the rotary type helms and make steering feel easier when it is working as it should.
      If you go to a rotary ,look at No-Feedback (NFB)as it can be let go of while underway and doesn`t spin free like a basic cheapo version.
      Also realize ,older wheels may have a straight taper instead of the standard 3/4`` taper all new ones will use.Adds $30.00 to the price for the cheapest ones in plastic ,while a SS wheel will run a bunch more if it can`t be re-used.
      Hope this helps.....
