So, as most of you are aware, I purchased Arthur from Robert over the winter. Arthur is a 25 foot 1960 Skagit with a 312 ford intercepter marine engine. Until now, Arthur has spent all of its life on the Columbia at Portland in freshwater. The engine is a direct cooled engine and I plan on using it in the south sound and on the canal. I will be trailering the boat and rinsing out after every usage, but I'm still worried about salt water in the engine.
I called Charlie up at pugetmarina and he told me that a new cooling system would probably run me around $3000, if I could even find one. For those of you with a lot more experience than I do, do you think I should do some more searching and find a cooling system or just use the boat as it is?
