Hi all, the outboard that came with our new Express is toast. It's a 50hp, which seems like overkill. The 40's I've been looking at are really expensive. Would a 30 hp work? We'd be using it to fairweather gunkhole, but currents can be quite peppy around where we live. Thanks in advance for your input!
Best size outboard for 1957 Skagit Express
I have seen Lots of Over powered boats and even a 17 foot,. I have seen them with twin 50 Mercs, twin 35 OMC's but for the most part, just in My opinion, I would use something close to 60hp for family and gear. The thing is, you never have to run the WOT anyway.
I had a 20' Skagit with a 55hp on it and with two people and all the fishing gear, it was Hard on the motor. I have a 20 offshore Skagit with the B18 Volvo I/O and for me, that is about the best option out there. Engine simple to work on, sips fuel and dependable.
Lots of options to choose from.Helmar Joe Johanesen
Thanks, John & Helmar! Hmmm...good to know. I'll take the engine in for a second opinion. The hydraulic lift definitely didn't work and the mechanic tore into the motor enough to say it would be safer to get a new one so I wouldn't be stuck in Cattle Pass rowing. But the mechanic is selling new motors, so worth a second opinion, for sure.
Chuck added the hydraulic lift and it is not needed /expensive to work on. Did the mechanic have it running? Is there water in the lower unit? Rowing is not practical, backup is necessary, kicker twin engines a buddy boat Chuck had tow insurance. When my Dad got too old to mess with a gas kicker I got him a big salt water electric. The 50 evinrude needs a water pump and thermostat removed now if the bolts break off that would confirm toast. If you are 100% dependant on a mechanic you have to buy a motor he will work on.
