OK, I'm a novice on these outboards so, I need help with the timing on this motor. It's a 1971 50 hp Johnson Hydroelectric shift w/elec ignition. Last owner said it wouldn't run because of frozen points. Well, I took the flywheel off and to my surprize, no points. It also had the woodruff key sheared off so I replaced that. (probably was the original problem) But, now what? Please help me time this thing. It turns over real nice and has 150 lbs compression on each cyl. cold. I haven't checked for spark yet as I feel I should time it first. Any help would be greatly appreciated.
Buck
Buck
