I'd have no luck at all. So, I contacted Keelguard and they said I might attach my Keelguard that is coming loose with a two part epoxy and mentioned Devcon as one brand that could work. So, I bought two of the "Flow Mix 60 Sec. Epoxy" and looked to see if it required a certain amount of heat to work. All the directions said on the subject was "not recommended at temperatures above 200 degrees F". So, I got out my trusty thermometer and found it was about 140 degrees below that number. I cut the tip off and attached the nozzle. I squirted it between the hull and the Keelguard and held pressure for the required 60 seconds. Then it popped free. So, I got a couple of pieces of bent wood and four C clamps and clamped it in place. This morning I went out and removed the clamps and the Keelguard popped away from the hull. The 2 part epoxy was as sticky as when I put it on. I had spilled a couple of drops on the trailer and they, too, were still sticky. Now this is a self mixing epoxy so you don't put it on something and stir it. You just push the plunger and it comes out of two sides of the dual tube and mixes as it flows through the nozzle. Anyone want a real deal on a slightly used Keelguard. Never been in the water! Only two pieces nicked out of it to accommodate the bend at the bow.
