Aluminum 427 Crate Engines available from Ford
  • Aluminum 427 Crate Engines available from Ford
    If you are looking for a bit more go from that vintage runabout or cruiser, Ford has introduced a new aluminum 427 crate engine. This is a pushrod engine with forged stroker crank and is based on the Windsor 351 block.
    A real powerhouse it puts out 535 horsepower at 5600 rpm and 545 ft/lbs torque at 4500 rpm. Price? Are you sitting down? $13,595. If you aren't weight conscious a cast iron version is also available for a mere $8800.
    Stick one of these in your Skagit 20!
    How about one of Fords original monsters tweaked up just a bit with twin (!!) superchargers! It is a 427 SOHC motor built for a 1964 Fairlane.
    BRIAN FRANCHINI
    LAKE TAPPS, WA.
