Skagit not perfect
  • Skagit not perfect
    I am a Skagit boats since I believe they were one of the stoutest old fiberglass boats. Also I am a fan because I grew up about 5 miles from the Skagit factory and even went to school with Howard's son.
    Now to the flaw I have found in my 1958 Skagit 20. Have found that the wood in the transom on the starboard side is not connected to the outer shell of the boat. The plywood is 1 or more inches from the side of the boat and about a 1/2 inch from the fiberglass transom shell. I am not sure how far the gap is to the center of the boat. The port side is bonded to the outer hull and transom and is in good shape.
    My question to any of you that has replaced the transom on their Skagit 20 if this is the normal or did I get one that had a shoddy worker for the day. Hope Helmar, Marty and others can answer my questions. Ckint
    Hi Clint.
    I have cut a few out and all different it seems.
    Most did not go clear off to the edges of the hull either.
    Most of the ones I have gotten my hands on were pretty rotten so I can't say if it was attached or not.
    I have been in a Bell Boy where the fiberglass was not attached to the transom. Around the size of a basket ball.
    Same with the stringers, seemed like they kept changing designs in the rear were they would stop them before the transom..
      On my 404 the wood went all the way to the sides of the hull. Same on the Glasspar. however, when I rebuilt the transom on the 404, I got it reasonably close and then filled the gap with thickened resin. Then heavy glass on the corners to tie it in. Works great.
