I like it ! I like It !
  • I like it ! I like It !
    This Merc 115hp tower of power or aka a black stack will really push my G-3 right along....don't you think? Chuck
    Chuck
    After the initial launch you may not need water! Barry
      Got a side shot?
        Yea, but first don't you think you should attach it to the boat and hook up the linkages and gas first. That thing will suck up so much gas, you won't be going fast for to long.
          Excellent! Another worthy Addition to the 115 Class
          That's going to be scarry fast Chuck. I predict you're going to love it!
          That G3 is a foot shorter than my PowerCat. I'm running a 115 Black Stack on mine, it it does 50+. What prop are you running?
          When are you planning to take her out for her first run?
          Doug
            Doug, i was just having some fun seeing what it would look like on the G-3 ,so i roll it out along with the G-3 to clean up my side of the garage today. I thought it would be cool to get a picture with it behind the transom. I do have a 65hp SS Merc on it's way to me however. I hope to have the G-3 ready in about a month. Best,Chuck
              don,t you have to fix the transom first?the merc is 20"is it and you transom is 16" while you are rising the transom maybe you should make it thicker as while.i,ll wait until you do your test ran then i can see if i want to put a bigger merc on my boat
                Bill, It will have a 65 Merc short shaft with a good transom. Chuck
                  Chuck, your such a tease!!!
                  Gordon and Cheryl Davies
                    nice,i have to replace my transom cause i have a long shaft.
                      Chuck,
                      Before you take that out on the lake make sure your will is up to date.
                        Bill, i just thought i would have a little fun pulling a few people's chain. On the Farallon the transom was beef up to 2 5/8 so i know what you mean about that.Best,Chuck
                          Originally posted by Sammamish1, post: 3367
                          Chuck,
                          Jack, There is no way i would put that motor on the G-3. Even the 65hp Merc will be as fast as i want to go. What's a will ? Chuck
                            when i was taking my g-3 apart i found this tag and it said maxium hp is 75.
                              I will is a piece of paper stating that if anything happens to you I get the Farallon! Stray
