I found this 62 SanJaun inches from the Canadian boarder Today..It has a mercrusier 110..Pretty good shape for a unrestored boat, I don't have to replace a floor, transom etc, its been sitting a couple yrs. in dry storage... I checked compression before buying all popped at 155 lbs..I figured that was good..Got it home hooked a hose up and found why I got is sorta cheap (800.00)..The bottom of the exhaust manifold looks as though it has a spacer plate, and then a bottom plate which has a small crack close to the drain petcock..and of course water dribbles out..I will pull that off tomorrow see about finding a new one..any ideas?..I didn't get good pictures today as its storming big over here this evening....and a 350 mile round trip to add a Dorsett to the shop. It does have a nick/scratch free glass upper wind screen, and full camper canvas..
What I found today...
Very VERY cool. You have a rare one here. Dorsett didn't officially do I'O's until 1963, they actually started doing them in mid 1962 and some even earlier. An expensive option for the day.
The earliest Dorsett I/O's just had a cover over the bathtub sized splashwell, the later ones (early 1963 and forward) had a more modern hinged cover with seats on each side of the motor vs. the rear bench seat like in the outboard models.
You have the coolest color combo for 1962 and the I/O option offered for the 1963 models. That color combo wasn't available in 1963.
Below are the respective 1962 and 1963 brochure pages. Good score. If your going to sell her, I'd certainly be interested.
Todd
Originally posted by Dorsett, post: 3927Very VERY cool. You have a rare one here. Dorsett didn't officially do I'O's until 1963, they actually started doing them in mid 1962 and some even earlier. An expensive option for the day.
Todd
I pulled the motor this A.M. as the freeze plug behind the flywheel (the easy one) was acting up.I will write the #'s down tomorrow, while I scoure over this little sewing machine engine tomorrow...
Originally posted by timw, post: 3946Todd, Thank you for the brochures. I am not sure if this was a factory conversion..I dont know what year the little 110 was manufactured..
ID plate location?
Originally posted by Dorsett, post: 3950Dorsett actually contracted their earliest IO's out and then started doing their own in late 62 early 63.
The Cap'n"The beatings will continue until moral improves..."
Pat Drewery
