So, yesterday I took the family out for a run in the canal. We had a great time and despite the continuing fuel delivery problem, were able to truck along at about 4/5ths throttle the whole time.
However, when pulling the trailer out of the driveway it made a bit more racket than normal so I decided to double check the hitch connections. They were fine. But when I was shaking the tounge, I heard a noise that I wasn't expecting to hear and was none too happy to hear - sloshing in the bow! We continued on our merry way and I looked at it when we got home.
The main plug was on pretty tight and I had to use vice grips to get it loose. Once loose, it came out fine. Our driveway is on a incline so the bow was down, but I noticed some wetness on the plug. So, around the block to a steep hill I went. I pulled the plug and water came out. A lot. And it was brown. It ran out for a good minute or two before finally petering out. I tasted it and it did not have a salt flavor, which is good, but it was a lot of water and I can only assume that the brown is deteriorated wood.
The wierd thing is that the floor of the boat is solid as stone (otherwise I would not have bought it).
A boating friend of mine says he had the same thing on his bayliner. It was rain water that had seeped in at the hull joint. I'm not so sure I have the same potential, except maybe at the transom, as the front of the boat is just capped with no gap. The other thing is, it hasn't rained since well before I bought the boat, so the water has been in there for at least a month.
The question is: how alarmed should I be? and what can I do to dry the hull out?
