Officially Dead?
  • Officially Dead?
    Nothing from anyone? No projects? No updates? Nothing.
    Bummer. This was a hopping place just a few years ago.
    Well, I have been working on a Razorback little 14 ft runabout and the Bell Boy.
    I had this little boat setting here for a couple of years being stored for a customer and he decided to do a push to get it ready for paint.
    I can't say this is a better built boat that others as they were pretty sloppy in the build.
    This one they put the two half's together with fiberglass tape and with so many sharp edges it was hard to get it apart without getting yourself cut to ribbons.
    Once I did have it cut apart, then noticed they Did use more wood than I thought.. Built the transom just a little thicker to hold a small 4 stroke. So I had to cut the splashwell tub and shorten it up a tad. Replaced all the wood in it and now waiting for the floatation foam. Because the top is flipped over on the hull for the wood replacement, decided due to it has No floatation in it at all, to add some. So the Fins will be filled with flotation foam and the same with the wasted space forward.
    It also has two seating area boxes that has drain holes that are open to the box so its just a matter of time those fill with water and the boat goes down. So decided to take those and run a tupe forward and aft along the keel for drainage and fill those with foam..
    Its kind of a V hull design but the last 3 feet it goes Flat so there were a couple of stringers back in that area that were like the transom, you could dig it out the wood with a plastic spoon..
    The Bell Boy, just fitting the PVC foam panels in for the floor and getting those ready to glass up.
    Oh, and the Razorback has a newer trailer. I was able to find a trailer (no pictures yet) that is a low profile with the smaller tires and wheels on it but these are the Wide smaller tires like a airplane would have. He is going to paint up the trailer to match the boat so it should look pretty cool.
    How about Mr Kelly, any progress on your end ?
      Just spending every weekend working on the hardtop. Updates are in my thread.
      I guess it's you and me in here.
        I'm still here! Retiring at the end of May and will have more project time. A couple rotten pieces of wood to replace in the Sylvan and I thought buying aluminum meant no more wood. A couple more Bearcats to put together. Now that's where the abandonment is. Damn near everyone dumped them. I'm assuming Bill still has parts but looks like Ed has "finally retired". I took a block with me to Minden, Nevada a while back and had Dale at Service Motors do some valve seat work on one that dropped a valve. Planning on using the boat more now.
        '70 Bearcat 55 (1)
          I need to get this lower unit up and have you help me if you would, put it back together as a non leaker. I am excited about that other Bearcat hood too. The one I have is pretty plain.
            I've got three weeks off in May, burning vacation time! Will work a grand total of 7 days in May! I should have some time to fix you up. After that I'll have all kinds of time except when I'm boating
            '70 Bearcat 55 (1)
              I see adventure bearcat marine still has a listing. I don't know if he is still in business. He had all the new old stock and bought all the stuff from the seattle dealer and a couple others.
                I thought he got out a while back. Ed's shop is still there as Zemp 4cycle marine.
                https://zemp4cyclemarine.com/
                '70 Bearcat 55 (1)
                  Way cool
                    Who says you can't teach an old dog new tricks? Learned something from a co-worker, whenever we had to remove fitted bolts from shaft couplings on the tugs, Steve would use the air hammer to drive them out when they were tight and we had room. Worked slick! The center long manifold bolts on the Homelite/Bearcat, there's a high percentage chance they are rusted/siezed in the block and usually break off upon removal. I wanted to remove the manifold on my F block the other day and of course these bolts were not cooperating. I put one of my straight gear wrenches on the bolt and then started lightly on the bolt head with the air hammer until I could increase the hammering and still control the tool, with hand pressure on the wrench and in a very short period of time both bolts were free.
                    '70 Bearcat 55 (1)
