Hi All:
Hope everyone out there is enjoying the fall and hopefully you are enjoying the water as well. I was out on the BellBoy yesterday performing some sea trails since I had done some maintenance work on my Merc. I had my mechanic change out the water pump and impeller while I watched. Now the procedure is a lot less intimating! I decided to change the pump because it had been six years since I had done so and also because the tell tale (peeing stream) was quite warm after running the engine at wot for a while.
Since the the new pump was installed, I am getting the same warm water results. I know everything is operational. I just wonder if those of you with stack 6's have noticed the stream being quite warm after high speed engine runs?
Love to get some feedback on this!
Best,
Bob
Best,
Bob
