Woody meets dock
  • Woody meets dock
    AAARRRGGHHHH !!!!!!! After a accident free summer, seems I cannot take the old girl off the lift anymore. While warming up in fast idle.....the ancient controls sliped into gear, the boat went about 6 feet and into the end of the slip. Looks like the totaly perfect wood hull will need a little TLC over the winter. I should have my Capt.'s card revoked !!!!!!! ST
    Steve Tweit
    1955 Mansfield 17' express
    1960 Rynell Jetabout
    2007 Bxxxxxxx "daily driver"
    Ouch...
    Steve -
    We've all done it at one time or another. Two years ago I was poking around inside the Boat Haven Marina in Port Townsend, looking at old boats, when my throttle jammed...naturally just at the wrong moment. Luckily, the target I bounced off of was a crusty, bulletproof old fishboat. No harm done to the collision victim, but it sure was embarassing...and could have been much worse. (Mark Denis filled some of the gouges when he did that nice work restoring the Bell Boy 16.)
    Looks like you escaped without serious damage, too.
      Yikes
      Good thing it wasn't pointed out "to sea" or you would have had to chase it down! Are the controls the boxy single handle white ones? Are they spring loaded to help you shift into forward?
      http://www.sandeace.com
        controls
        Hi Ed....Yes , the old box, single lever. No spring loading. I would like to swich to a better system...any ideas ???? Hows your weather ??? Steve
        Steve Tweit
          I like the somewhat older 2-handle controls. Using those makes it seem more sporty like a stick shift in a sports car.
          8 degrees predicted for tomorrow. Above zero, at least. Not much snow.
            When I was setting up the Poker Run with Cole year, we had a mishap with a dock and my Tolly. The boat will always pull to Starboard when in reverse, so I come into the dock almost bow on, turn to port and click it into reverse. Usually pivots right around to the dock. On one of our last stops, I did the same docking procedure and as I clicked from neutral to reverse, the engine coughed and died. I now have a 6" long scratch in the varnish on the starboard side of the bow. Time to rethink the docking procedure!
            Let me know if you need a hand with it Steve.
            BRIAN FRANCHINI
            LAKE TAPPS, WA.
              Yep, I think Ole is right. All of us have done it at one time or another.
              Not looking too bad, hope its an easy fix.
