Hello everybody,
I'm Pats,
I'm from a small community in Northern New Mexico (population 11). I'm retired and enjoying it. I'm the proud owner of a 1964 Dorsett Catalina. I have been working on it since I bought it, about 5 years ago. I have been doing some upgrades and building some add-ons for it. Although I live in Northern New Mexico, I keep the boat in indoor storage at Ute Lake Reservoir, Logan, NM (near Tucumcari) about 300 miles away. It's a beautiful boat, and I really enjoy having it. I wish I could keep it here at home, but the winters are harsh with to much snow. And the lakes in my area tend to freeze over, and aren't very large. So, I keep it at Ute Lake. Its a fairly large lake that was made by daming the Canadian River. The weather there is fairly moderate, and with a little preperation I can use my boat all year long. I especially enjoy going in the winter, I've learned that in the winter, I can have the lake almost entirely to myself. It makes for quite an adventure, as most of the lake is very remote, with no outside access or roads. I don't know if you've tried it, but the Dorsett Catalina makes a great winter boat. Sometimes I will stay out for up to 10 days, the most limiting factor being: fuel. I am in the process of researching some type of a (safe)permanent tank storage system, with at least 30 Gal. capacity.
The last time I used my boat, I damaged the transom. When I bought the boat, it came with a 115 hp Mercury Outboard, which is way overpowered. I have never been able to use full power/throttle, there's just too much power. I've always thought (but not sure) that the transom was a little weak due to age. Appearance-wise it looked ok, and seemed fairly strong. However, I must have pushed it a little to hard, and cracked the transom and outer fiberglass (there is no inner fiberglass layer, only tabbing), where the motor mount bolts pass through. I didn't realize at the time the transom was cracked, and the boat didn't indicate any change in performance. I spent the night in the boat up a small side canyon, with the starboard side of the boat tied to the shore in shallow water. During the night while I slept, water seeped in through the cracks, filling the boat with about 2' of water. To make a long story short, I had to climb high enough up the canyon to receive cell signal from Tucumcari Mtn., and called the Park Ranger. After about an hour and a half of pumping, we had the boat dry and floating, and made it safely back to the ramp.
I loaded the boat on the trailer and took it to the storage area and cleaned and dried everything. The next day I located a man that owned a small tractor with a front end loader. Together we undid the controls and trim pump, then lifted the outboard motor off of the boat. Then, I started taking pictures and did my best to assess the damage. The next day I headed home.
Since that time, I have been discussing the damage and repair with the techs at Fiberlay, Inc.. I had their help in putting together a materials list, that includes, laminating resin, hardener, chopped strand mat, 1708 fiber mat, structural putty, ribbed rollers, etc,. I have spent countless hours watching youtube videos about: transom repair, laying-up fiberglass, wetting out fiberglass mat, rolling out bubbles, tabbing, fillets, etc,. During my research, I found my way to this website (NWCBC), I looked at the forums, in the boat restoration topics, there is so much information and knowledge that I was almost overwhelmed. I now have many new ideas that I want to try, but can't until I finish these repairs. Some of the materials I can't get until I get there, due to lack of room in my truck, large items such as, marine plywood, door skin, etc,. I have bought several new tools, oscillating multi-tool, 5'' orbital sander, 4 1/2'' angle grinder, plus, bits, blades, grinding wheels, hopefully everything I need.
I hope to make my first trip to start the repairs on or about Oct 2nd, and I'll stay about ten days.. I'm not sure what I'll get accomplished, but if I can get the old plywood removed, the fiberglass shell sanded and faired, make a pattern for new plywood out of door skin, cut the two plywood pieces according to pattern, resin coat the two new plywood pieces, drill a screw pattern in the fiberglass shell & plywood pieces. then start laying-out and wetting-out mat and install the new plywood using sheetrock screws in the pre-drilled holes to support and clamp the new plywood,.....I'll be happy. I'm just going to go about it "slowly but surely". I am going to do all the prep work and have everything ready and laid out, before starting the laminating of the new plywood. I'm only going to mix small batches of resin at a time. Hopefully, everthing will go smoothly, and I have enough energy and stamina to get this far the first trip. If you have any advise or tips you think I might need, don't hesitate to let me know. I will greatly appreciate any information or advice you might have.
There are times that I feel "overwhelmed" by the size of the job I have ahead of me. I will try and take some pictures of my progress, and post them when I get home.
Here are some pictures, so that you can see why I like this boat so much:
