A friend loaned me a late model Mercury 4 stroke 2 hp outboard to use for a day of crabbing. The clamp to one of the brackets that holds the motor to transom broke as I attempted to loosen it to go over the transom. It was frozen and I twisted too hard. I went to the local Mercury outboard dealership and he said the bracket is no longer available. So, I went online with the part number (10-898103A66) and got the same answer everywhere I went. If I, at 81 years old, can snap that cheap little plastic thing off by hand, there was must hundreds of those little motors setting around totally unuseable. I would have thought there would be a replacement part number or one could be pulled off a junk outboard somewhere. I don't want to tell my friend what I did to his motor (which I then didn't even get to use). I need help and help now to get a replacement. Any ideas? Anyone? Please!
Help, help, help!!!
Thanks John. I give Seaway Marine a try. If it were my motor, I'd put something together but I borrowed the motor from a friend and want to give it back to him in very good condition.There is a very fine line between "hobby" and "mental illness.":shocked4:
Thanks John. I had no luck on eBay and Pacific Marine Exchange in Bellingham, where I used to find everything I ever needed, closed its doors last year. Tom, Tom, where are you? I don't know when my friend is going to ask where his outboard is that he loaned me.There is a very fine line between "hobby" and "mental illness.":shocked4:
Originally posted by Lootas1 View PostThanks John. I had no luck on eBay and Pacific Marine Exchange in Bellingham, where I used to find everything I ever needed, closed its doors last year. Tom, Tom, where are you? I don't know when my friend is going to ask where his outboard is that he loaned me.
In the upper right side of your screen, you should see Notifications, My Profile, Settings, and Log Out.... You should click on Notifications and you would find the message there.
I would call you but we try not to use phone numbers in the texts here but your "My Profile" is not up to date so I can't call you.Helmar Joe Johanesen
